Direct Offline Load/Import of Autodesk DWG format
You seriously need to make it to where we can directly import and save from a DWG Autodesk file. I have a small part... 23K, a polygon with two holes... the import took 20 minutes!!! That's horrible.
I simply cannot imagine what it would take if it were a complex part.
I'm in the trial stage for this product... and so far not very impressed with import capability. I believe that this level software should be able to import and then directly save it locally... often I am in an area with NO WiFi support... remote field locations. The software seriously needs to be able to function without WiFi support.
