I've been looking for a way to make the same simulation study for the same model but with different parameters and still see the results of each simulation without having to rewrite the previously made. It would be an excellent idea to add something were the previous study does not be affected when the parameters are change so comparison can be made between each results of different parameters. If there is a way to do that inside the software without having to build a report I haven't found it. Is better to just compare it inside the software than to have some computer memory to be taken to generate a report for each simulation.
