Show only
Search instead for
My request its very simple, I would like to have the ability to create a diameter dimension on a circular pattern, where you pick the center of the main circle first and the diameter of any circle on the circular pattern, thanks.
If this request is similar to the need to dimension something like a bolt hole circle or clearance circles, I am in agreement. We can use such a feature.
It need to make a center line that is a circle, and each hole of the pattern should have a short center line straight that intersect with the center of the patern rotation point.
on the center line circle, we can put the diameter, maybe the diameter can be added automaticly when you create the center circle line, it's allwas faster to erase something created automaticly then creat it when it's not done, but this is just an idea.
