Currently, when using the measure tool, the delta XYZ only shows up when selecting two points. In solidworks, the XYZ deltas shows up, even when you select two edges or even two faces (see pic below). Sometimes you just want to know the X distance (or y or z) between two parallel lines rather than the diagonal.
Also, the distance line should not be green, it is easily confused with the Y delta at first glance.
