Current stock + toolpaths Preview
This is something that is semi-possible in HSMWorks but I would like to have it decend.
So what I'm looking for is this:
While programming it's often hard to know what you have machined and what you haven't. So you would want the software to show you that.
This video shows what is possible now in HSMWorks but for all the Autodesk CAM solutions I think we want it updated.
https://knowledge.autodesk.com/community/screencast/f62bcc6d-30f4-4d4a-8c12-205b4b78573a
If you enable the show stock preview feature you want it to show all the stock removed upto the operation that is selected.
If nothing is selected preview everything that is in the active job/setup.
But when you select an operation you still want to see the toolpath lines. Which is currently not possible it's one or the other and we want both.
3 Comments
Could this be moved to the Inventor HSM & HSMWorks CAM Ideastation so everybody using Autodesk CAM can vote?
al.whatmough
Status changed to: オートデスク審査落選
shaneU6DLB
 Does anyone know if this is possible yet? Its driving me nuts not being able to do this coming from software that does have it.
Cheers
Shane
