Converting a mesh to a solid body
I would love a feature that could take a high density mesh file such as an STL and turn it in to a solid,   It wouldn't even have to be a T-splines body,   just a dumb body that was as close to the original shape as possible.
Right now the limit for Fusion (and solidworks)  is 10k triangles to convert from STL to solid.    I can upload the same STL to Fusion though, and get a mesh body.
I would love a tool that would convert that high polygon mesh body directly to a solid.
3 Comments
colin.smith
Hi @madengineer13
There will be improvements to mesh handling in Fusion in the next few months.  One area that we are looking at is a better way to work with higher poly count mesh models.   Can't comment on when this would happen yet.
Colin
madengineer13
Thanks  for the reply!   looking forward to these tools whenever you can fit them in.
Regin_THZ
The ZW3D CAD has a command under "point cloud->Trace Region" that can create profile curves from the meshs silouette. It's a bit of manual work to trace all surfaces but you can extrude the same body from these curves when done. Maybe a similar approach could be implemented but one that traces all the regions around the whole mesh leaving a set of curves/edges in 3D space. A bit crude maybe but this procedure is very fast.
