We are facing the lack of an advance finish or 3D-equivi distance type finishing toolpath in milling. Sometimes we run a finish tool path for walls and we like to run it on flat or steep faces as well. If we make a toolpath with horizontal distance between passes (step over) and vertical distance between passes (step depth) at same time so it will give us a complete finish on entire part.
