I understand that importing geometry is a popular request. I also understand that the status is now "Implemented" Still I have to ask where is the add or Import button?
Here are some thoughts and observations on the subject:
Drag and Drop in the Dashboard
Note when I tried the drag and drop function it works for the initial establishment of a file but when I tried to add a surface into an existing file I get a crash document.
Drag and drop should work while the file is open as the workflow needs to accommodate all potential outside geometries.
Import button
The default should be to all available file types with easy filter for type.
It would be awesome to be able to parametrically connect imported bodies to a folder where as if the imported body is developed further by other when the FUSION files is opened it re-imports this updated / changed file.
