Show only
Search instead for
Also, when two heights are the same and you are viewing from "on end" one can't see both colors. One hides the other. If you could make those 2 color lines appear as a set of bi-color dashed lines. You would immediately know that they are both at the same height. Sorry my olive lines aren't drawn straight but you get the idea.
This is a good idea that can be leveraged not only in CAM, but also throughout Fusion 360 where color coding is needed and improved. We are looking into this right now to see what are some things we can work on right away.
