click group to select all
A simple way to select a large number of bodies that are members of an autocreated pattern group.
1) generate a small object
2) create a circular pattern with hundreds of copies
3) combine those into a single object by joining with another body
expected: it is possible to select all with a single click to the group
actual: it seems necessary to open the group, click on the first, scroll through all instances and then shift+click on the last object
3 Comments
keqingsong
billbucket
How is this implemented?
I'm calling semi-BS on this being implemented.
Apparently you can click the top, scroll to the bottom, and shift+click to select everything in between, but that's a major PITA when it involves scrolling through a list that's hundreds long.
You should be able to select everything in the container by selecting the container, itself
