CAM Workflow Improvements
I think It would Be a good Idea to have a short cut /Hot key for editing your cam operations. I thing it is time consuming to have to right click then move your mouse up to click Edit , Now You may be reading this ,and think, that it doesn't seem that hard of a task , but the thing is I find myself  bouncing between operations quickly and end up missing the edit button several times ,end getting frustrated on how tedious it is to edit an operation. If there was a short cut key that all you would have to do is ,click the operation, and hit a key. That would make things run smoother , and also would be a good idea to have a hot key for simulation as well ,
Please give suggestions on what keys would be best ,and if this would be worth doing for an update.
Best Regards
                      Logan McCleary
2 Comments
kb9ydn
Have you tried double clicking?  That's pretty fast.
C|
thetechbros2015
Wow didn't even know that was a thing, I though just double clicking slow was for renaming the operation.I didn't know there was such a thing as Fast double clicking.. Thanks for the tip.
