99% of my work is acrylic sheet routing, rarely changing tools. If I have an array of 34 .25" holes to bore/pocket with a 4mm or 6mm tool, I have to select each face/hole at a time. The Geometry "Select Same Diameter" option in the Drill function would be fantastic in the Bore options. Emphasis on Fantastic.
