Show only
Search instead for
Indeed, I've wondered the same thing. Even better would be to make the right click menu context sensitive and have all the relevant sketching commands (including constraints) available from there, instead of the sketch palette which (IMO) takes up too much space for what it does.
This is a current limitation we have. The text on the left of the command dialogs is not clickable. We are currently looking into some UI updates this is one of the things we will put on our list to consider.
Our right click menu is actually context sensitive throughout the product. If you select two sketch entities and right-click to get the context menu we display the constraints that can be applied as a relationship.
