In the CAM section, tool library there is a way of editing a tool spanning several operations in your setups.
One thing i ran across was i broke a 3.5mm endmill on a setup that hade 20+ operations.
And needed to replace each everyone of em with a 3mm endmill. That is one hour of my life i never get back.
A right click "Replace tool" option in the tool manager menu for the specific document would do just that. And then you could mass edit all similar operations in one go instead with the compare and edit option.
