Assembly Environment a joint should be move along a path not straight.
Add a Particular type of joint  in Assembly Environment of Joint which can relate two component by providing a path or curvature... In Slider joint component has straight line  joint they move only straight line path.. We need component should move along a path..
Particular joint along a curvature profile relate between two components
2 Comments
New Joint  should be needed
Add a Particular type of joint  in Assembly Environment of Joint which can relate two component by providing a path or curvature... In Slider joint component has straight line movement. they move only straight line path.. We need component should move along a path..
 By choosing such a Joint it will include only motion along a given path.
lure23
Good video describing your use case, @Anonymous
Are you aware of Curved Slider Joint entry that discusses this. It would be useful to get VOTES there, since Autodesk claims they decide on feature priority by the votes given in IdeaStation. That entry has a notion that they have picked this one for "Future Consideration" (back in 2016).
