allow primitive Cylinder and Cube to grow All directions !
With a cylinder primitive I can only extrude into one direction - that is limiting when for example you need symmetry.Screen Shot 2017-01-13 at 7.19.29 AM.png
With a sketch as a start and then extruding it I can extrude into both directions.
So ideally the primitive should grow into both directions.
Currently I would need to extrude the other side by as much as I defined the length of the cylinder
adding an additional modeling feature to the timeline.
2 Comments
keqingsong
Status changed to: RUG-jp審査通過
In this case, we recommend users to start with sketch instead of primitives. We currently have no plans to improve primitives and are focusing on higher priority projects.
cekuhnen
@keqingsong This goes back to the sketch free working thread and the issues that were discussed there.
