With a cylinder primitive I can only extrude into one direction - that is limiting when for example you need symmetry.
With a sketch as a start and then extruding it I can extrude into both directions.
So ideally the primitive should grow into both directions.
Currently I would need to extrude the other side by as much as I defined the length of the cylinder
adding an additional modeling feature to the timeline.
