It seems some CAM operations, like 2D adaptive clearing, can't do rest machining. In my case, I'm doing two subsequent adaptive clearing passes, one with a large tool, one with a smaller tool. Some users have proposed doing other clearing operations in between adaptive ones, but that seems like a clunky workaround.
I'm not sure why Fusion 360 can't just support rest machining on all operations.
On top of this, the rest option on the operations that do support it ask for input about the previous tool size. But this should be available to the CAM engine by way of the previous operations. In cases where the previous operation didn't machine anything (say, because a selected pocket was too small for the selected tool), subsequent rest operations are skipped, even if the tool is small enough to enter the pocket. In those cases, the tool path should be designed to enter the pocket safely given that it is full of material.
In fact, all operations should be rest operations, shouldn't they? At least by default?
Thanks!
