Add a keyboard shortcut for Edit Form
I would take any key, but since Edit Form is is the press pull of sculpting.  Maybe we could get "Q" to launch Edit Form when in sculpting mode.
Press pull is already pretty smart.  Pre-Selecting a face will launch Offset Faces,  a profile launches extrude, an edge launches fillet, etc.  Would like to pick a face, vertex, or edge on a t-spline body and get Edit Form.
Thanks.
3 Comments
SteveCox3D
I'd totally agree with this and fully support the idea (I was about to submit the same idea - good job I checked).
The Sculpt webinar run by the Street Team on Jan 20th showed how pivotal the Edit Form function is in the Sculpt workspace and is often the first thing you need once your Sculpt entity has been created.  It's a good idea to make the shortcut 'Q' if possible so that it matches a similar function in Model mode.  If the software architecture prevents this then any other free key would do.
DrNefarius
Or better still, much of the functionality should be available straight in the sculpt space, with no need to go anywhere before starting to sculpt away.
blacktip
Indeed! Having to go up and click an icon hundred times is very annoying.
