Ability to export results
I run simulations and then I want to be able share at least a 3D visual of the results with my team that does not have CFD. They all have either fusion or AutoCad or Mechanical. It would be very useful if we can share the results easily.
Comments
Autodesk Support
Autodesk Support
You can save out Dynamic Images which are vtfx files. These can be opened with the CFD viewer which can be installed for viewing results on machines where you do not have/want CFD to be fully installed/used
