Automatic Selection of Holes When Creating Bolted Connections
To have an automatic selection of all holes that match in diameter when created mechanically bolted connections by means of either a beam or spring element.
When having a component whereby you have to manually insert 100 bolted connections separately, it becomes extremely time consuming and tedious.
