QA Tags / schedule Tagged Elements
We can set up views and schedules that allow us to cross check filled data, make sure fields are not left empty etc
However, one thing we are not able to check easily is whether an element has been left untagged or un-annotated.
The reason this would be good is because 2D sheet views still, and always will (for the forseable future anyway) form the contract documents.
If something is accidently left untagged, like a steel beam, it doesnt get priced and someone is open to a claim when the mistake is discovered.
Personally, i would probably like to see a schedulable field that lets you see what annotations (multiple if there are more than one) are assigned to each element.
Even just a yes or no answer. If it's tagged somewhere in the project, even multiple times the answer is yes, if not, no.
When we select a tag, there is a button to 'pick host', so to my non-programming mind the data is there, there just needs to be a way to extract it.
Thanks for reading :cara_del_revés:
