The order of Spot Elevation parameters.
- The parameter of "Rotate with Component" should be categorized "Text"(not "Constraints").
- The parameter of "Elevation Origin" should be categorized "Constraints"(not "Text").
- The parameters should be sorted in the order of the below.
1. Elevation Indicator
2. Elevation Indicator as Prefix/Suffix
3. Top Indicator as Prefix/Suffix
4. Bottom Indicator as Prefix/Suffix
