Stacked Wall Improvements
Stacked walls could be greatly improved by allowing the height controls to reference a level, per basic wall assembly defined in the stacked wall. The could be done with an additional column or two indicating "Level" and "Offset From Level". Right now, if the level heights in a project changes, the stacked walls have to be adjusted manually.
Additionally, I've noticed that stacked walls don't respect their location line settings in instance properties the same way basic walls do. This also causes unexpected behavior when you change from a basic wall to a stacked wall.
If something doesn't make sense, I'd be happy to provide additional information.
Thanks for the consideration.
