Edit Assembly (Structural Responsibilities)
When editing a double brick wall with a cavity you are only allowed to pick one element (function) to assign structural responsibilities. In some instances you can only pick the element that is within the two core boundary wraps, in some instances you can pick any but it's still only a maximum of one element you can pick from. In reality when building a double brick wall the two masonry act both as supporting structure. Sometimes you can build three or four bricks depending on the structural responsibility the wall has to undertake in it's entire thickness. Please make this option of assigning structural responsibility to every function assigned as "structure [1]" without limiting how many functions (structure [1]) can be structural. This should make for an even more accurate structural analysis.
Thanks :cara_con_una_leve_sonrisa:
Comentarios
El estado se ha cambiado a: Archived
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community (votes or comments) over the last 24 months and as such we will not be pursuing it at this time. Please feel free to re-word (titles and clear descriptions are really important) and resubmit this Idea.
