Rotate Project North: rotate everything
Rotate Project North doesn't rotate everything in a project, see https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Would be nice if it _would_rotate everything. And when on the subject, name the command Rotate Project, since it doesn't rotate the north-direction itself.
