Editable Room Boundary/Merge Rooms
I'd like to be able to manually edit a room boundary and/or merge adjacent rooms into one room.
Comentarios
Between "room separation objects"  and "room bounding" property of walls/doors- looks like what you want to do is covered.
While i like the idea of Merge rooms (one of two rooms is deleted)- Revit may have trouble figuring how to accomplish this - i.e. which walls/doors to use to achive desired result, assuming you have already indicated which room to keep.
The way I envisage it,  the two adjacent room boundaries could stay the same for merging, it would just be scheduled/ tagged as one
It would be great to be able to edit the profile of a room boundary the same way you edit the profile of a wall, for instance.
And also a reset profile button to go back to default boundary.
That would be amazing, @Anonymous!
