"Type Mark" of Host Element in Rebar instance Property instead of "Mark"
I would like to suggest that Read only parameter "Host Mark" in Rebar instance parameter should be Type Mark for better Documentation.
 iI will be nice getting automatically the host "Type Mark" in this Rebar instance  parameters so that we can easily sort the rebar  schedule for each type mark.
Comentarios
Hi. Did you found solution of this problem? I have similar case: I wodu like build Host Mark as sum of given parameters. For exsample Host Mark = Mark + Instance numeber + Parameter 1 + Parameter 3 ...... Do you know how to do it?
Something can be achieve using dynamo.. Are u familiar with it?
I'm familiar with it. Looking for definitione right now…..
What I feel that create an instance shared parameter for rebar... Using get
element parameter node in dynamo collect all the required parameter value
from rebar then add all this strings to one string... and using set
parameter by value node.. Feed this value to the rebar.
