MEP in groups
I got an issue with groups in revit
While doing MEP i consider important the use of some comands that are not available, i would like to use the next ones (I am currently using Revit 2017 and i cant do this while in group.
-Cap pipes
-Connect Into
-Change the workset of an item
This may be minor things but while working on a big proyect, with several groups it becomes annoying not being able to do this, and it becomes annoying to place a fitting, look for the cap, and then try to put it to the pipe, or erasing the item, changing workset, and then doing the item again.
I hope you do this minor changes, think may not be a huge innovation as many other ideas, but while doing several MEP proyects it will help productivity
