Allow tags in exploded axonometric views
I think it would be useful the ability to tag or keynote everything in a exploded axonometric view
Until now, its imposible to tag a displaced component in an exploded axonometric view.
Regards.
Comentarios
You can do this for tags. Lock the view, then use the "Tag all" tool instead of trying to tag the individual objects.  Revit will tag the objects at the center, and you can then move the tag.
You will want to set the tag to "Free end" as you can see from the wall on the right in my photo, the leader goes to nothing when turned on.
Keynotes lack this feature, so adding user or element keynotes I haven't been able to make work. Material keynotes, however, worked just fine and were able to find the object faces.
Quick Example:Type Tag in Axon.jpg
Thanks J.Mounteer.
I didnt knew that.
But it's a pity that tagging with keynotes is not totally implemented, only keynote tags by material or by user are allowed.
Here, in Spain, its common to use keynote files linked to external databases generated from QTO programs like arquimedes ( http://arquimedes.cype.es/ )  or presto ( http://www.rib-software.es/presto.html ), and tagging by element  in  a exploded view would be a great improvement.
Thanks anyway.
I agree it would be a good improvement to allow keynotes of element and user type to work as well. At least we're not locked-out of the tags, however!
El estado se ha cambiado a: Accepted
El estado se ha cambiado a: Implemented
This feature was implemented in Revit 2023. Thank you for your contribution to improving Revit!
