Flowcalculations for sanitary pipes
I would like to make views with filters that tells me when i have to step up a size when needed. I know how to do this, if Revit would calculate the flow in my sanitary pipes automatically, based on the plumbing fixtures and other compatible komponents.
Thank you!
Comentarios
I've seen people create Color Legend views in which the pipe colors are indexed to a range of fixture units.  Each pipe size has its own color.  This way the user can go through the model and update the pipe sizes manually, but using the colors as a guide.  It's not fully automatic, but it does work.
