Revision Arrows
The ability to create "revision arrows" would be amazing for my sanity!
Whenever I move something on a drawing that has went out for Tender, I then need to put a move arrow from where it was, to where it will now be. This arrow is just annotative and isnt associated to the specific change.
If we had "revision arrows" where they were assigned to that particular revision, then they would disappear when applying a new revision and turning off the "bubbles/tags". This way, I wouldnt have to remember where each and every arrow is as they would just disappear when I turn them off.
Also vise-versa, if I want to turn on the old revision, then the arrows from that revision will re-appear (rather than me having to open up the PDF to see where those arrows are since I would have had to delete them for the next change).
In short - Add revision arrows to "Clouds and Tags" that can be turned off when turning off the clouds/tags for a specific revision. Would make life so much easier!
