import DWG's control
When I import a DWG from a third party (witch I often have to do) and if the import drawing contains (solid) hatches and 2D solids I get a big black blob in that section. Then I must open the DWG, remove all the hatches en re-import. It would be great if I could toggle an import function with or without
hatch.
To be short more DWG import control.
Comentarios
