Allow Per Sheet Revit Keynotes & Make Simpler To Use
Revit should be able to do per sheet keynotes. Often I just want to add one or two or three quick notes to a drawing and be done with it. I want to number them 1,2,3 etc and have them just exist on this sheet only. I don't want to have to create a unique name and fit them into a global scheme.
The whole keynotes system is kind of backwards. It is almost centered around the idea of having a fixed set of notes that you then apply to a set of drawings. It really should be the other way around. You should be able to add and edit notes and have them dynamically manage them in revit. You shouldn't have to go out and maintain a separate text file and reload.
