Copy/Paste from separate sessions
Revit is based on Windows.  You can copy/paste from program to program regardless of the program in Windows.
But for some weird reason you cannot copy/paste from two different sessions of Revit, only from within the same session.  When working on a memory intensive project, it is better to have another session of Revit running instead of the primary in case of a program crash and lose both projects.
Why?
It works for AutoCAD.
While I know Revit is NOT Autocad.....Revit is based on Windows and we cannot do this simple task.
So....Why?  Please fix.
Comentarios
I agree!
So....I may have to say that this is implemented already.
I had a project in 2016 and a project in 2017 open.  I didn't want to retype a text note from the 2016 to 2017 so I tried to copy/paste.
OMG it worked!
Can anyone verify from 2016 to 2018 or 2017 to 2018?  I don't have 2018 yet.
@Anonymous Text will copy between sessions and between different versions. The Idea is for all the other items in revit that will not copy like a schedule or a drafting view.
Autodesk Please merge this thread into...
https://forums.autodesk.com/t5/revit-ideas/copy-paste-between-two-different-revit-sessions/idi-p/7509065
@Anonymous  What version does it work in?  2017 it does NOT work!
Text, lines, etc cannot be copied from two separate sessions of Revit.
I already mentioned that selecting text itself and pasting into another text object works.  I want to be able to grab an entire page of text objects from one to another in separate sessions, not the same.
Also, the post you are referring to merge should be merged with mine....I posted 5 months before the other one.
