Ramps
When You section a ramp (a solid one) you notice that the starting point shape is quite impossibile. It's a geometric form (a triangle) but it lacks of thickness. this is clearly wrong; every item in reality is thick, especially a reinforced concrete ramp. it's time after so many releases to correct it.
Luca
