Combining Dimension Strings
Please could we have the ability to combine dimension strings.
Splitting dimensions is great, thank you. But if someone has created a bunch of single dimensions, or accidentally broken a string and can no longer undo the action, it would be really helpful to be able re-combine.
A way to integrate this (from an end-user perspective) could be using the 'edit witness lines' of one dimension string to select another dimension string to combine the two?
Thank you for your time.
Comentarios
Community Visitor
Community Visitor
Or if you have a 200 foot wall with 30 different dimensions, and you want to place ONE MORE dimension in the middle of it. It would be great to do anything without any worry. I want to select, delete (this splits the string in to two strings), add that dimension, and finally COMBINE the middle of the giant string back together again.
CombineDimensions plugin for Revit is released on Autodesk App Store!
https://apps.autodesk.com/RVT/en/Detail/Index?id=5462412800925779313&appLang=en&os=Win64
By:
https://formtechdbs.com/
