Vertical Schedule Orientation
Be able to toggle from a horizontal oriented schedule (elements in rows, parameters in columns) to a vertical schedule (Parameters in rows, elements in columns). Currently Revit only supports a horizontal schedule.
This would allow more flexibility for what can be fit on a sheet. Vertical schedules especially makes sense for scheduling a few elements that have many parameters you need to schedule.
Comentarios
For example, an air handling unit schedule with only a few units, but many parameters to define the unit.
Yes please! We have exactly the same requirement for AHU's, fans, boilers, pumps, and a variety of other equipment. Currently we simply don't schedule these items within Revit and have to use our own Excel exporter.
Seems like a basic feature to me! Just flip the schedule vertical instead of horizontal. Thanks for suggesting :cara_con_una_leve_sonrisa:
Yes please!
Observer
Observer
Definitely NEED this feature!!! PLEASE
A lot of mechanical schedules are oriented vertically to fit on sheets because of the amount of parameters needed.
Definitely needed!
NEEDED!
You know its bad when an AHU schedule might not fit on a 30x42 sheet depending on what a certain title block looks like.
I think it would be very very useful if Revit allows us to list the fields in a schedule vertically as well.
The horizontal format it is too restrictive.
ex:
Unit Area          0.00
Balcony Area     0.00
Total                 0.00
Rather than:
Unit Area      Balcony Area      Total
   0.00                0.00              0.00
Thanks.
This ranks in the needed column for me as well.  Large equipment with many parameters look ridiculous being broken up into 3 or for separate schedules just to get them to fit.
I just listened to the "What's new in Revit 2019" webinar and checked the Revit Road Map.  I am really disappointed that schedule appearance and formatting is not mentioned on either.  Architects and engineers are generally very attentive to detail and appearance.  The lack of schedule formatting options gives us no alternative but to be chronically ashamed of our schedule sheets.
Basically, the entire engineering world has been using spreadsheets to schedule equipment for decades.  If we use Revit's equipment schedules it makes that no longer possible.  Therefore, there is no excuse for Autodesk to not make basic spreadsheet functionality, in terms of function and formatting available in Revit.
Autodesk is missing a major opportunity to revolutionize the way equipment data is managed.
This is the same idea as the below link, vote for both!
https://forums.autodesk.com/t5/revit-ideas/vertical-schedule-orientation/idi-p/7040737
Here is a pretty typical thing we have to do to break up out schedules and make them fit. This is scheduling 3 electric boilers....2019-04-15 07_41_45-Window.png schedule 1 of 2. Anyone have better workarounds?
We still use excel for ONLY this reason. I would really like to get away from that but not being able to format the schedules the way we want is unacceptable. For what a Revit subscription cost It's very disappointing that this basic feature has not been added yet.
@devonpowell, that looks like a pretty good workaround. This limitation has made my company become more selective when deciding which columns remain in the schedule. For instance, almost all of our physical dimensions have gone away since we model these elements very closely to the actual equipment. Additionally, we've combined some fields and grouped under a common header like what's shown below. This can really buy a lot of space with temperatures (if you can use abbreviations like EWT, LWT, EAT, LAT). I think you could squeeze your schedule down to one without much sacrifice.
All that said, this is a silly limitation.
On a slightly different topic, how did you create the general notes and specific notes? Something like "Insert" a row below the title, and merge accordingly? Or did you use some other magic?
@Evan.S.Hallyou are correct on your notes assumption.  just insert a row or 2 under the title and then combine as needed to get the required number of columns.  Shift+Enter is your friend when getting the text to wrap as desired, and for each new note  :cara_guiñando_un_ojo:
@Evan.S.Hall  - Agreed, and especially for that boiler schedule we could squeeze it down to one. Other pieces of equipment like an Air source heat pump with heat recovery modules it becomes harder. But good point on using abbreviations, etc. to shrink it down.
confirmed on the general and specific notes.
Please add this feature!
Yet another design firm not using the built in "smart" schedules simply because we desire a different orientation.
Pretty please with sugar on top.
This seems like a pretty obvious feature that has been missed / ignored for Revit!  It would be of huge benefit to most companies who want to use Revit to create schedules.  Please add this as a matter of urgency for a future release! :cara_que_hace_una_mueca:
This would make life so much easier, please added Autodesk.
Absolutely necessary! Please do it now!
This is a verry BASIC functionality that most people would excpect to be there. The amount of work needed to make workarounds for this type of presentation is HUGE. Should honestly just be a one button press to change between vertical and horizontal orientation.
We build switchgear schedules and diagrams from other information in Revit. Currently we have to use excel to import the "vertical schedule" sticky using the Ideate Sticky addin (which is very good) but it would be preferable to keep all the data within Revit, which this feature would enable us to do.
We use DYNAMO to change data input but what our really problem its about the graphically organization of the information in Revit. For example, if you have to mange 50 parameters in a room, it is very difficult to work in a horizontal way in Revit.
@Anonymous , exactly.
I'm disheartened that this post is 3 years old, and now news of this update from Autodesk.
@devonpowell, it needs more votes...post a link for all your colleagues to help the cause!
yes please add
we are using revit 2017 architecture
and for door window scheduling we are facing same problem
Currently we are going with 2D detail with legend component
Autodesk, how is this not a feature yet? What am I missing?
*Ability to format a schedule so fields are shown as rows instead of columns.*
This does not compute in light of the yearly subscription cost basis for usage of this software.
3.5 year old idea, many votes. Come on.
O my goodness the amount of clients that have asked me this - come on Autodesk, if you can crete tools for social distancing, im sure you can make this simple request happen!!!
+1, Yep, c'mon Revit, this is a no brainer...
Community Visitor
Community Visitor
Why is this still not resolved! :cara_llorando_a_mares:
UTTERLY DISAPPOINTED that this is not a feature in 2022!!! (that i can see)
Please correct me if I'm wrong here.... I would really love to be wrong.
Come on Autodesk - its no wonder architects are complaining about the lack of improvements. We shouldn't be asking for this stuff still 5 years down the line!!
@kimberly_fuhrman-jones please combine with @devonpowell link
Has anyone solved it????
I wonder if someone at Autodesk could provide some insight into why this hasn't been accepted yet (or even put "under review")? There is clearly a lot of passion about this one and if there are some technical challenge or other roadblock, perhaps some on this thread might have some ideas of how to overcome.
WE NEED THIS!
This would be amazing.
This would be a game changer!
This would be extremely helpful!  Make this work for key schedules as well though.  (e.g. Hardware Set key schedules for instance.)
You know what we really need is an idea that simply states, "Make Revit Schedules Work and be Functional like Excel Spreadsheets".  That would lump everything together and about say it all.  :cara_con_una_leve_sonrisa:
Thank you!
Yes, we've only been asking for this basic function for five years, now would be good??  Is there anyone out there in Autodesk-world listening? (beyond those taking our subscription fees?)
Community Visitor
Community Visitor
As the demands for information in models keep increasing we have a hard time meeting our clients demands with the tools we have at hand. This simple and basic feature alone would have saved us hundreds of hours in workarounds to be able to present information the way our clients wants over the last 2-3 years.
It is even so basic that it is hard to grasp that it doesn't exist. You have no idea how many employees that ask HOW you change the orientation of a schedule. And no one believes that it is true when you tell them that you can't.
You really need to wake up on fixes like this. This is a basic feature that you'd expect from ANY software or web based service in 2022. And the fact that it doesn't exist in a world leading Architectural software?!  Hello?
Pitty to still see no update on this issue that is 5 years old now in this thread. Revit 2023 doesn't seem to fix this as I scroll the updated feature list.
Can we all post messages in this thread to get it a bit more coverage?
Community Visitor
Community Visitor
Is it so difficult for a developer? 6 years ....
Observer
Observer
I was trying to search for more information about the issue and seems like Autodesk has not or doesnt make any move on this one. Autodesk please give us an update or might as well a solution. Thanks.
Maybe we just need to keep posting to gain enough attention.  Years have passed, still nothing?
Come on Autodaesk guys, make an effort!
Try with an AI if you feel you can't do it by yourself!
Community Visitor
Community Visitor
Yes I need it.
This should have been possible years ago.
Community Visitor
Community Visitor
Totally agreed with this function, schedules need to be more graphics adaptative also.
Community Visitor
Community Visitor
Hi, autodesk ? Are you there ?
Please, please, please Autodesk, add this to the roadmap at least!
Hard to understand why this is still not a feature...
found this on AUGI from back in 2010 - The ability to create horizontal rather than vertical schedules (augi.com)
Does Autodesk even look at AUGI wishes anymore now that they stopped the ability to add new wishes?
The original idea here was first posted in 2017, so 7 releases since starting Revit 2019 in 2018 and still nothing. Is annoying when simple ideas like this are ignored which are required by so many, but Autodesk add niche features like elliptical walls as seen in Revit 2020, which will hardly ever be used  as most designs will be rectangular in nature.
I also need this. It seems like it would be really easy to add this option and I have so much information that needs to be presented in this format that I am forced to import from excel because Revit can't do it natively.
Make this a reality please, its ridiculous this still isnt a feature. It is almost there already, the schedule can be flipped on the sheet, just make the values horizontal on the sheet!
Community Visitor
Community Visitor
Please add this feature! So necessary!!!!
Autodesk, are you listening ??
