In desperate need of an "ortho" type of function that forces items to be drawn at 90 degree angles. A vast majority of my projects are plumbing and 90% of the plumbing items that I draw are drawn at 90 degree angles. I have attached an example of one of my projects.
Having to push down the shift key each time I draw a pipe is not an acceptable solution because that means 90% of the time I am drawing piping I have to hold the shift key. Also having to go into the Pipe settings to un-check all of the other available angles is not a reasonable solution either.
Can you help please?
