Flexible conduits
Here in Australia we are modelling more and more 'sweeping bends' conduits, mainly due to the new NBN (National Broadband Network)
Revit does not allow us to draw a conduit with a radius in one go, we have to attach bends etc, this does not work in this scenario, we need to have one element but this is not possible without drawing an 'in place' family each time, which is totally unviable due to time constraints/changes.
Surely it would not be too hard to draw a conduit from point 'A' to point 'B' as you would a spline in CAD?
Comentarios
Thanks for the suggestion.
Can you elaborate what actually is meant by a flexible conduit?  E.g., a reference to a manufacturer's product, link to PDF, or other relevant catalog information.
Please refer to my original post, it is all the same conduit as we always use, mainly 23mm OD in the NBN installations, but instead of a rigid configuration of the conduits using bends, elbows etc, it basically goes from A to B as the crow flies but with a 'flexible' path, the installers here actually call them 'sweeping bends' as the conduits will NEVER be installed in a straight line.
My problem in revit is that when I want draw a conduit from point A to point B, if using the path that the conduits will be installed to, revit will produce loads of minor bends, which then screws up my scheduling, therefore the only way to draw it properly, is to do an in place family, but on tower block installations etc, this will be hundreds of conduits, which makes it impossible to do, therefore we have to cheat to get the end product as revit makes un-feasible to do!
Martin we specify Anaconda Metallic Flex conduits for use in Electrical pits from conduits to Cable trays here is the link to give you an idea
http://www.anamet.nl/products/anaconda-flexible-conduits-and-fittings/
They work very similar to the flex pipework for sprinklers so i would assume you could use the same technique where you connect to the end of the conduit and run from there they would just require different fitting types.
Martin,
If I think the addition of a Flexible Conduit function is becoming more critical for Revit. In Australia we use a lot of what is called flexible conduit, in transport and commercial street lighting and services.
Link to flexible corrugated PVC http://www.clipsal.com/Trade/Products/Catalogue?c=1&ms=5&s=14&mg=385
I think having a Flexible Conduit function essentially the same as the Flexible Duct or Pipe in Revit, except with conduit connectors is essential to proper electrical modelling.
I have not seen any mention of this in 2018. Is this something in the works?
Regards
Sean
All the electrical designers need a flexible conduit, liquid tight, etc., conduits that can be quantified, scheduled a so on in Revit.
Thanx
I'm relay surprised that Autodesk has missed this type of conduits .... Its widely used in electrical installation .. I wish to see it in the next releases of Revit .
I forwarded this on to every Electrical modeler I know. Hopefully this catches on and gets more traction. Good luck :cara_con_una_leve_sonrisa:
@grahamlyon1977
I totally agree with you. This is a must-have for electrical installation.
@martin.schmid
You could probably use Flex Duct from HVAC as a template for the flex conduits.
That´s pretty much how they should work.
I think what is being described here may be two separate things...
1. flexible corrugated PVC - which may be similar in concept to Flex Duct/Flex Pipe in Revit.  Have you used flex duct / pipe to model conduit presently?  Does it provide you with the control and capability that you need from a geometry perspective, or does it leave anything to be desired?  The reason I ask is that we've had requests for folks that have attempted to route PEX piping, and have struggled, as the functionality was designed for flexible connections at equipment more so than routing long distances, and on multiple planes.
2.  in the original post indicated "all the same conduit as we always use" and "allow us to draw a conduit with a radius".   what I interpret that to mean, and along with the provided image, is that he is looking to have rigid conduit that allows bending to conform to a large diameter radius.
@Martin__Schmid
What I was originally asking for which may be a little lost in my initial explanation was the functionality in Revit MEP to model an electrical conduit the way you would model a flex duct in mechanical services.
I need to model a conduit at the normal diameters (23mm, 50mm, 100mm OD) from Point 'A' to Point 'B' like we would draw a spline in AutoCAD. it needs to snake around corners etc and be on the system category of electrical conduits.
Why would we model it as duct/pipe? it's an electrical fixture.
This is a major problem in Revit MEP to just have the function to model 'rigid' conduit, the practical application for this is not like this anymore.
My initial post has a screenshot of a drawing from AutoCAD, if we could replicate this function Revit MEP and have as a 3D element, this would make mine and many others lives easier!
@grahamlyon1977 - thanks for the clarification.
to address your question, "Why would we model it as duct/pipe? ":
This was was really more directed toward @dominikleuchter 's suggestion that "could probably use Flex Duct from HVAC as a template for the flex conduits"...
My inquiry in the prior thread seeing if this was truly the case... as I stated:
Does it provide you with the control and capability that you need from a geometry perspective, or does it leave anything to be desired?  The reason I ask is that we've had requests for folks that have attempted to route PEX piping (like this and this), using flex piping, which is basically the same editor as Flex Duct... and they have struggled, as the functionality was designed for flexible connections at equipment more so than routing long distances, and on multiple planes.
Sorry for creating confusion here. I may have expressed myself wrongly.
Basically i meant it as g.lyon wrote it. A flexible conduit as additional family and not a Flex Duct/Pipe replica or something.
What I actually wanted to say was that it should have the flexibility of Flex Duct / Pipe.
I have not used Flex Duct / Pipe in detail yet but I got the idea from trying out several standard Revit Familys to see if there is one with similar to the flex conduit we need.
Sorry everybody. Emoticono feliz
Might try it out and see if this is the case.
Thx for clarifying @dominikleuchter - my question still stands... I'd still be curious about the ability to model w/ flex pipe/duct... if you had the exact same geometric functionality to model flex conduit... what works well about it?  what doesn't work well?  If you have chance to give it a try, it would be interesting to get that feedback.
Martin
It leaves Six things undesirable:
-Past job we uploaded our Revit model to the General Contractor for clash detection. Forcing us to use "flex duct" as an electrical device sometimes plays havoc on the coordinators clash files because they will inadvertently use system filters to separate and export Trade designated coordination models into Navis for clash detection. Since Flex duct is not an electrical system, it ended up in the Mechanical contractors NAVIS clash file. This was a Lesson learned. The solution was to use a "work around".
-Primary and secondary panels with a transformer in-between them we have to use a conduit elbow for GTP then filter out off for coordination upload, we use the flex duct as the flex connection because in actually can fit more like the field install. If this was an electrical system GTP would probably update their program to "connect" these on the autonomous one-line.
-Creating a BOM for Flex/Liquid Tight we have to add an extra step to the schedule so its description is correct.
-Have to customize fittings with conduit and flex duct connectors on each end.
-For BOM reasons-cannot get an accurate Run length to calculate wire lengths. The flex or liquid tight does not get captured in the total length of the run. We have to manually add length, (this is AKA a "workaround").
-GTP does not automatically recognize Flex Duct at final equipment connection, have to use a manual "work around" (use conduit that will be filtered off on Coordination model export) as opposed to the program autonomously adding the P.O.C. intelligence.
The electrical "Flex" family needs all the descriptions from the NEC (National Electrical Code-North American).
Here are a few examples:
-Flexible metallic Conduit (MC) i.e. aluminum or steel
-Liquid tight Flexible Metallic Conduit (LFMC) i.e. Steel, Aluminum
-Liquid tight Flexible Nonmetallic Conduit (LNFC) i.e. PVC
The Cable and Wire Family needs all the descriptions from the NEC (National Electrical Code-North American).
Cable and wire would have absolutely created value for my department on our last job for BOM purposes. Using conduit as cables in tray was very cumbersome, modifying conduit would inadvertently delete or move sections of tray furthermore the bending radius of wire is smaller than what Revit would allow for the conduit.
-Cable i.e. Triplex, TC or other types, Sometimes cabling can have a 3.5" O.D on these.
-Wire i.e. THHN 500 mcm Cu.
Please try to push this product improvement especially when this has been posted for over 3 years.
 Hi @Kevin_Laskowski - thanks for those details, very helpful to understand the scope of the problem... I am still curious, from a geometric perspective, if the way that the flex duct/pipe geometry itself behaves, have you run into any particular challenges when using it to geometrically represent flex conduit... or if it works perfectly well... e.g., if the same geometry/modelling interactions were applied to a flex conduit element, would you be happy, or would you say, "when I'm trying to do certain things to get the flex to route a certain way, or be at a certain elevation, or go through a particular point it doesn't do what I want."
Martin
It works extremely well . Possible attribute to add would be minimum allowable bending radius based on type and diameter.
 An example for Armored Cable (AC) would be NEC 320.24 Bending Radius.  The radius of the curve of the inner edge of any bend shall not be less than five times the diameter of the Type AC cable.
 An example for metallic Clad Cable Cable (MC) . The radius of the curve of the inner edge of any bend shall not be less than required in 330.24(A) through (C).
(A) Smooth Sheath.
 (1) Ten times the external diameter of the metallic sheath for
cable not more than 19 mm (3⁄4 in.) in external diameter
 (2) Twelve times the external diameter of the metallic sheath
for cable more than 19 mm (3⁄4 in.) but not more than
38 mm (11⁄2 in.) in external diameter
 (3) Fifteen times the external diameter of the metallic sheath
for cable more than 38 mm (11⁄2 in.) in external diameter
Hi @martin.schmid
I did some testing with the Flex pipes to answer your question about the "geometric perspective" you asked for.
@Martin__Schmid  wrote
... I am still curious, from a geometric perspective, if the way that the flex duct/pipe geometry itself behaves, ...
Here my opinion on what works well with Flex Pipe and what doesn´t:
- Basically the way Flex Pipe can be placed / drawn works as we need it. Especially, the possibility to adjust it afterwards (through "vertex" and "tangent" points). That's the kind of flexibility a flex conduit should have.
- What is missing is the possibility to place it in a section view.
- Visually, the Flex conduit should basicly look like a standart conduit and on "Coarse" detail level simply like a line (maybe dashed, that's at least our standart)
- As Kevin wrote, minimal bending radius, adjustable in the electrical settings - conduit - size (just like for the already existing rigid conduits) would be nice too.
- The "Paralell conduits" function should also be working with the flex conduits, if possible.
- Also good would be the ability to connect the flex conduits to rigid conduits (like Flex Pipe / Draw Pipe)
As an alternative to a completely new flex conduit family with flex pipe as a template, you could add a bend fitting to the existing conduits that can be draw and adjusted like a spline. (if that's easier / faster for you to add)
Or you could add the "Draw" option to conduits, which is known from beams. (They can be placed as Splines.)
@grahamlyon1977  and @Kevin_Laskowski feel free to correct/complete me.
Hi @dominikleuchter
What you have summed up (expertly by the way!) is exactly what I was after when I originally posted this!
Maybe if we get this incorporated, we may move onto the other deficiencies Revit MEP has on us poor miserable souls that do Electrical :cara_con_una_leve_sonrisa:
My main ones to tackle next are
1) busbars
2) electrical wiring
and THE MAIN ONE THAT DRIVES ME INSANE - RAKED CEILINGS!!
I have posted all of these on this ideas page, maybe we get gain some support?
With the conduit we use today, it´s not possible to design true BIM Projects (Plan as built). With three significant improvements, we could avoid most of our Problems we have today.
1. Flexible Conduit
In concrete buildings most of the conduits are flexible. To draw realistic Models, electrical engineers need a flexible conduit, like the flex pipe.
Picture of flexible conduits in a concrete ceilingPicture of flexible conduits in a concrete ceiling
2. Systems for Conduit
Conduit can contain different Type of media, for example a data-cable or a lighting-connection. To specify what’s the conduit used for, we need the possibility to classify them into Systems.
Sample of an electrical plan with different Systems in different colorsSample of an electrical plan with different Systems in different colors
3. Wire in Conduit
Conduits contain different wires (single or multiple). For true calculations there must be a possibility to add wires in our conduits.
Guten Tag
Warum kann man die Flex Funktion welche in Lüftung und Rohre existieren nicht auch im Elektro machen? Würde vieles vereinfachen. Dies hatte ich schon vor langem vorgeschlagen.
Felx pipe/conduit is needed, please add
I would like to echo the need for this. We like to use Revit to model street light and other outdoor electrical systems, mostly because we have all the drawing standards set up and prefer not to change tools unless we need to, and also because the callout features are very helpful. And often we have buildings with associated parking lot lighting and those buildings we are designing in Revit.
Street light ducts are 32mm and easily bend to follow gentle curves. We draw these with model lines at the moment but what we'd really like to see is a flexible duct system that responds to control points and vertexes.. similar to an AutoCAD polyline.
I tried using a flex duct and it sort of works, but I feel the ability to modify the path after it is placed initially is absolutely required. If the system had some knowledge of min bend radius that would be sweet but I'd rather see something soon rather than wait for something really fancy.
Is there an idea posted about this?
As it is possible to simply do Flex Duct (FD) and Flex Pipe (FP) in Revit, it would be great if we also have a Flex Conduit possibility (and not the flex pipe edited family originally for Plumbing purposes, or some adaptive generic made up ones).
I have opened a request to be voted on regarding the existence of the flexible conduit, to avoid the alternative use of flex pipes for plumbing purposes or generic adaptive components. Who knows, if more people vote, this old request is prioritized. If you agree too, please, help by voting at the link below:
https://forums.autodesk.com/t5/revit-ideas/flex-conduits/idi-p/8794216?advanced=false&collapse_discu...
There is no option for flex conduit in Revit platform, but in actual site condition, conduits are sometimes twisted, slightly bend for coordination purpose. So whenever we try to match those as built conditions (Point cloud), we are getting error warnings. If possible then add flex conduit option or add vertex option in conduit.
This is very essential for BIM modeling.
101 votes and counting! Will we see this in a release soon Martin? I'm completely underwhelmed by 2020 but this is a feature that would get us off our 2019 perpetual license.
The Idea is that we will have Electrical Flex Pipe in Revit.
When we must modelling 3D pipes in Revit, we don't have an option to modelling flex pipes for this.
We have only the option to modeling "no flex" conduit.
Kind regards.
Observer
Observer
We are also in North America and use the NEC.
In addition to the types listed above by Kevin.Laskowski, I'd like to see ENT Electrical Non-mettallic tubing (Smurf tube), which is very similar to the corrugated pvc linked by Sean.Lawrence above. | NEC Article 362 Type ENT
Also type MC cable| NEC Article 330 Type MC
Flexible Metallic Conduit has a designation in the code as FMC | NEC Article 348 Type FMC.
As far as the functionality of the different tools flex duct/flex pipe, I haven't had much of a chance to use them, we've been modeling some of our flexible conduits straight with the standard conduit system families.
https://forums.autodesk.com/t5/revit-ideas/add-flex-conduit-option-or-add-vertex-option-in-conduit/i...
and also this one. In order to give more relevance, make sure to use the search and vote for existing ideas.
CABLE LAYOUT FOR SUBSTATIONCABLE LAYOUT FOR SUBSTATION
Hi
the above cable layout is done for a subsation project.
does any one have a idea for cable laying , where the cable used is flexible (flexible conduit properties) , restrains to a specific bending radius , and can contain a no. of cable within a master cable which can be seperated for further connection.
in fact, my job very very need to draw the flexible conduit and electrical rubber cable according to the point cloud, but it is not in Revit platform at present, it is so inconvenience.
I hope it will have added soon in next Revit platform or product updates.
If there are flexible pipes and ducts (very useful by the way) Why are there no flexible conduits ? To carry cables are used a lot. It would be interesting to use them.
This is a duplicate of this idea:
https://forums.autodesk.com/t5/revit-ideas/flexible-conduits/idi-p/6343138
Note the identical title. Please search the site before you post.
I called attention this idea during my presentation at the inaugural AutoDesk Building Engineer Virtual Meetup this morning. The vote count was 133 when I took the screen shot for the presentation.... We had 180 participants and I hope some of those people will take the time add their vote.
Sorry. You're right. Can I delete the post?
Thanks very much! the more votes the better!!
Disappointing. Only four additional votes. I will be pointing this one out again in my presentation today.
I was about to start a new idea... but I see it is already here. Yesterday I got an email from Autodesk to let them know about which features should be included in next revit version. Well, here it is!... please allow us to have out-of-the-box flex conduits with materials and/or colors to differentiate visually all types of circuits (lighting, outlets, lightning)... This would greatly improve Revit performance!
Another vote to add this feature for all the electrical modelers out there!
I'd even suggest to have electric systems such as plumbing and HVAC have, to have a more complete tool.
Lighting, outlets, lightning, solar, eolic, coming from battery... systems.
Searching for an answer to this problem (newer modeler) and was disappointed to see that a post from 2016 still has no good solution. This definitely has my vote, having a hell of a time modeling massive amounts of conduit racks that transition from rigid to flex multiple times. Hope we will see this is a new version before too long, seems pretty critical.
@Martin__Schmid for displaying purposes- yes it works either flex duct or flex pipe. However, there is something _*terribly*_ wrong about suggesting that as the reason autodesk would _not_ implement the change as suggested. Something that makes BIM pointless. The whole appeal of BIM is that I can obtain supplementary info such as costs, material lists, and _very important_ information for integrators such as what is what is shown, what discipline does it belong, etc. Conduit and pipe, while pretty much similar in nature, not only do they follow very different construction guidelines, _they are used for very different systems_ . Conduit is used as a raceway for cabling, ducts are for transporting air in HVAC and pipes are for fluids (liquids or gasses). Not only is suggesting to use a type of material that is not the correct one antithetical to BIM, but: 1. Filters would not work as intended. I do _not_ wish to lose half of my raceways in a view because what I wanted to filter out were the other disciplines. 2. In the real world, ALL conduit may be bent with the adequate use of tools; having the program adding fittings not only makes listing materials harder, it limits what the model shows in comparison to the real world. Case in point: you need to make small bends to a conduit in order to couple it seamlessly to a junction box of _any_ height. The fittings create a minimum height for these transitions that is limited by the bending radius of the fitting. 3. Flexible types of conduit (FMC and LFMC) have their own accesories- again it makes listing materials harder and unallows the model to draw the adequate accesories.
5 year for a simple request? YES we need flex conduit that comes with 1-price schedules 2-connectable to assets panels lights switches pull box 3-pvc and metallic type 5-benable and free form draw 6-work with offset 7-have hanging placement for ceilings 8-most important part is wire type inside it we put wire in conduit not water so wire type and gage is important part and again 5 year for this handy feature is not right
How much more traction is needed for this to finally get into Revit? Holographic design tools might be invented by the time this gets implemented :cara_con_la_lengua_fuera:
This idea is a need in Switzerland aswell. I have a similar idea,  would appreciate your Votes to :cara_con_una_leve_sonrisa:
New improved Conduits - Autodesk Community
If Autodesk Developers were actual builders they would understand the need for such basic conduit functionalities. Yeah generative design is cool, but to truly bring the BIM into Revit, they should listen to such basic needs. This has been a request for several years now.
Until when Autodesk??!!? Until when indeed!!????
It would be really nice to finally have flexible conduits added to the Electrical system families. This is a very common product for Electrical Engineering. It is very usefull for prefabrication an for power cables in or beneath the foundation.Flexibele Buis Elektra.png
@kimberly_fuhrman-jones, you have linked in my original post on your thread :cara_con_una_leve_sonrisa:
This is my original post and I posted this in frustration 6 years ago! still not implemented by AutoDesk, with over 342 votes!!
I will post again next year. Let's keep flexing our comments......
#FlexibleConduits
Maybee we have to comment much more..
#FlexibleConduits
We want to use Synchro 4D, problem now is, when using automatic Filters to place 3D content into scheduling fragnets. All of our flexible electrical conduit has to be filtered under "Mechanical". If we were at the GC level putting this together, All of our content would be accidently placed under the Mechanical subcontractors timeline. If there was a family named electrical flexible conduit, no work arounds would be required. Please consider this post having value. Mechanical Flex alone will not compliment 4D scheduling anymore.
@grahamlyon1977 , thank you for pointing that out!
Since it was still an active thread, we are trying to consolidate as many duplicate posts as possible. Combining threads also helps to boost the votes. With over 9000 active Ideas, it is easy for Ideas to cycle through activity. Please know that votes are just a part of the selection process for our product teams. I encourage you to watch this YouTube video where our Product Managers explain the selection process.
Thank you for your Idea submissions!
-Kimberly
Community Visitor
Community Visitor
#ElectricalFlexibleConduits
Flexible conduit would be a great addition to the electrical tool bar.  We shouldn't have to use mechanical flex as a work around.
Make ELECTRICAL flexible conduit for REVIT a reality, there's already Mechanical flex pipe how hard could it be to implement for Electrical installations.
Agreed with the above. A flexible conduit family for the electrical discipline is something that has been on our wishlist for years. It would be a huge boost to coordination to get this added.
Incredible how little Autodesk knows about construction materials and processes. Yeah generative design is cool. But just give us the actual tools we need in 95% of real projects apart from the shampoo bottles which are 1% of whole world built projects.
Community Visitor
Community Visitor
posted this 6 years ago, still no movement from autodesk?
this is now an essential element to electrical revit modelling, Revit 2023 just came out, nothing really useful on a daily basis for Electrical really.
@martin.schmid - any movement on this idea??
we still waiting for the flex conduits... I am also interested in the movement of this idea...
Hi Autodesk,
Could you please tell us when (#ElectricalFlexibleConduits) could be implemented in Revit?
It's been more than 6 years that this essential, very commom and pretty obvious elements is requested by the comunity and apparenlty it is not even clearly planned on the Revit roadmap.
We have Flex Ducts, we have flex pipes but no electrical flex conduits as per snip below.
Why would be so hard/complicated to implement this?
How many votes would we need to proceed with this?
Where could we vote and give more visibility to this?
@Martin__Schmid
This is the most commonly used electrical material in Latin American countries. I'm guessing since this is not as used in the US, Autodesk just doesn't care.
Please add these as well..
Flexible Conduit (FMC/FNC)
I work as BIM manager for one the UK's largest energy providers. I've been Revit user since 2004, certified trainer 2016-2019 and to date there is no cable function. Cables are one of main function of the business. As the business transitions from 2D AutoCAD to Revit the need for a cable function is a must. We build MV, HV and HVDC substation across the UK connecting wind farms, solar farms, battery storage and multi terminal links to other countries. There is a LV, MV, HV cable add-in at $500 for each type but it's just a conduit system and will not perform as needed (Waste of money). Revit hasn't changed that much in 18 years with minor changes year on year. Can the Autodesk Revit developers look into this as the building blocks are already there is just needs to be developed? I hope I'm not searching for solutions 10 years from now. I'm sure I could get most of the business to vote (22,000+ employees) if this would make Autodesk to listen
Observer
Observer
Flexible Conduit for Electrical, please.
I find myself tasked with drawing underground conduits for quite a few of our projects.
The ability to use an arc (or a spline) for conduit would match reality in trenched conduit situations.
Many times the trench is cut in an arc to eliminate elbow fittings underground.
I have never modeled conduits the way you are describing, but I've seen the radius of the bends changed from their default values, to something like 240" (20ft). This gives a more realistic visual of underground conduits.
You can always take this a step further and create a new conduit standard that uses the 240" as a default bend radius, but I feel like a 240" radius may become problematic in some areas where stub ups are closer together, and Revit won't let you reduce the radius to anything less with out of the box content - so it may be a little trial and error determining if this is a good long-term solution or not.
If more of us comment could we maybe get some movement on this?
Also in the New Year we need this, lets move.. Since 2015 we need!
This is Autodesk listening and taking care of their customers' needs. I've long accepted Autodesk will not bring this into Revit.
I asked the Electrical manufactures to rename liquid-tight to "Flex duct". It just another work around but at least it puts the onus on another trade for a bit Until Autodesk adds this Family to the Electrical system.
Is there an update about this flexible conduit suggestion?
Unfortunately no response from Autodesk or what so ever. Just some possible “backdoor options” I don’t want to know about, because the whole idea is use the frontdoor…
I run into the same problem when modelling indoor Distributed Antenna Systems, I would like to connect the CAP's with the system's splitters, couplers and antennas.
All I need is a rigid conduit/pipe with the ability to turn into a flexible "end" that is editable into a 7/8" and 1/2" coaxial cable. I'll fill in the rest of the parameters myself.
By now we all know that Autodesk is about flashy ideas that can make it into the AU Keynote and how to bring the WOW factor into the show... and not really into giving Autodesks customers and the AECOM Industry in general basic tools they need to do the job.
It sometimes still seems that MEP is subordinated to architectural and construction, while the share of the installation sector has become increasingly important over the years. In practice there has been a real shift in this share, but in theory this is still treated quite conservatively, if you ask me. This shows that these types of ideas remain at the bottom of the list, no matter how many voices are raised...
                  Agreed. I stopped contributing a long time ago, even beta test. Just done with this format. waste of time.
even with 1000 votes it won't change anything... maybe in Revit 2025 :cara_guiñando_un_ojo:
@dsevieri10 - This post has been edited due to Community Rules & Etiquette violation.
This is ridiculous that we've been asking for this for years and we still haven't got it.  They already have the families in mechanical and plumbing.  All they need to do is add it to electrical. ridiculous!
Still no Flexible conduit....
Yes, sadly no flexible conduit, the request has fallen the deaf ears of the REVIT overlords.
