Please provide an option for a Sheet Underlay. Similar to a plan underlay, it would show up halftoned, and snap-able. I would like to set up on sheet of plans, then underlay them on a sheet, and use them to align new sheets/views. They should be "Align-able" like views are when on the same shared sheet. This could also work with Sections/Elevations.
Thank you for your consideration.
