Shared Project Parameters / Details / Legends
It would be really helpful to have the ability to share project parameters, detail views / sheets, legends, general notes, etc from one location to multiple projects (live).  In an AutoCAD workflow, we can do this using xrefs to have one title block, one set of details, one set of general notes / legends, etc, attached to multiple plans, but in Revit, each RVT file currently needs to maintain it's own version of this information.  This is difficult to maintain across several RVT files in the same job.
Also, the term 'global parameter' would make more sense if you were able to pull the data from an external file of some sort, into multiple Revit projects.
Comentarios
I'm looking for a way to reference details between projects.  Everything's a work around with problems, there is no official Autodesk method that works to show the same detail in two files and updated it in one place.
Here's my idea for a solution:
Can we make linked files show 2D detail items, dimensions, and annotation items? This would allow details to be saved out into files as groups or views, then linked "by linked view", and updated either in the detail or by overwriting the detail file through saving out again.
