Design Options for MEP
MEP really needs to be able to use Design Options.
If there is some technical reason MEP can't model using DOs, they at least need to be able to specify which DO is shown from the Linked model.
Currently, the only option is to see the Arch's Primary.
The only way to see an Alternate is to make a copy of the Arch model, change Primary, and Link in the modified model.
