Revit Coordination Alert Window Show Command
I would like Revit to do the following:
When you use the Coordination Alert window, after selecting the coordination object (i.e. wall change), you can RIGHT CLICK and choose SHOW. This will make Revit display a view or cycle thru different views so you can see the objects that need coordination resolution.
Comentarios
