Having a split section line with straight and angled / curved segments
I did see an old thread that said this is not possible and when you split a section line you cannot angle one segment and that you should create two sections and merge them together. And things have not changed yet!
We are working on a building that starts straight and then angles and I am finding it hard to believe that we are the only ones who have done this! We would  VERY much appreciate the capability to not only split a section line (which we already can do) but to be able to skew (or possibly even curve!)  a segment of the section lines..
