Revit Links & enhancemets
Hi There,
* What I feel is at heart of revit if revit can remember the linked file and it's site geo-location this will save lot of pain. also Architects need not draw room bounding lines in fear of loosing link & rooms. also avoid having 100's of warnings.
* reduce the pain of handrails creation, this is such a pain in revit.
* can revit think of building something at the heart of revit, to avoid / warn if the lines, text, dim's & tags touch each other...this will save production time.
* can some of the Dynamo cool tricks be incorporated into revit
* reduce the complexity in creating families.
* why are there no escalators , lifts & travelator's built in revit like doors & windows.
* Architectural indicative levels are not always top & bottom of the element. some time the bottom level needs to indicate a level based on other disciplines...please look into it.
* reduce the pain of creating mullions, it should be more like a lego than like rocket science. after all this is design.
* staircases need headroom clearance feature as part of the design. this needs to be looked into.
* find replace should be able to penetrate to parameters level, not only text.
regards,
Wilson
