ELEVATIONS TAGS FROM THE CLOSEST STRUCTURAL ELEMENT
When you have to create MEP drawings you tag the bottom elevations of elements to be installed in the field, but the reference is a Level, so if you have many differente elevations of your Finish floor you have to create multiples Levels and then manually select to which level you want to reference every tag, this is really anoying and leads to multiple mistakes.
It would be great if you can take yous elevations automatically from the closest floor below the element, this will also help a lot when you have sloped floors or ramp where you have to manually take the distance.
Comentarios
good one!
