A tool to easily import parameter from an imported family
For importing parameters currently the following steps are necessary:
  - Open the Type Properties window of the imported family
  - Click on the small rectangle at the right of the row representing the parameter to import to open the corresponding "Associate Family Parameter" dialog
  - Click on the "New Parameter" icon on the "Associate Family Parameter" dialog to open the "Parameter Properties" dialog
  - Recreate a parameter of the same name by writing the name once again in the "Name" field of the dialog
  - Click OK in the "Parameter Properties" dialog
  - Click OK in the "Associate Family Parameter" dialog
...repeat the same procedure for all other parameters to import.
A quite cumbersome and time consuming procedure...
I wish there was a "check to import me" button for each of the parameters in the "Type Properties" dialog of the imported family which, together with the "OK" button, would do the trick...
