Offset Pattern Creator
Revit needs to have a feature within New Patterns to create an offset pattern! When you create a New Pattern, there are currently only two options: Parallel Lines and Crosshatch. There should be a third option for Offset for tile patterns. Currently I am using a third party hatch maker (RevitHatchBuilder) that can only create New Patterns in Filled Regions instead of directly adding the pattern to a new Floor which makes the Revit file larger over time (if you make enough of them). Alternatively, I know there is a way to do it in AutoCAD that involves many steps, however, I do not know CAD very well and wish it was simply part of Revit.
