Allow "Super" Template for all views on Sheet
Currently the dialog "Overriding Visibility and Graphic" has very little interest when it is used in a sheet.
It would be desirable for a template to be made which will apply to all the views present in the sheet, for example, to mask all the working sections, to apply a particular filter to certain elements, etc.
This would greatly reduce the number seen, and thus the number of templates, necessary for all particular cases to be printed.
In Autocad, it is quite possible to have some layers frozen in "Space Paper" and not in "Space Object". Same thing for the colors ...
